decrease idle rpm of engine?
Old Jun 21, 2009 | 10:37 PM
bingroy's Avatar
Default decrease idle rpm of engine?
1990 toyota camry V6. Did an overhaul of the exhaust system and oxygen sensors recently. However, while getting that done, the mechanic increased the base rpm of the throttle. Earlier the engine used to idle at 1000 rpm, now it does around 1200. How do I get my idle rpm back to 1000? Thanks for the suggestions.
Old Jun 22, 2009 | 06:49 AM
pedro's Avatar
On a car that old there may be an adjustment screw on the throttle body. Look where your accel cable connects to throttle body. Why would mechanic increase rpm? Even 1k rpm sounds too high, should be 750-800 unless you're trying to compensate for something.
Old Jun 22, 2009 | 11:45 PM
bingroy's Avatar
I dont know why the mechanic did this... by nature I dont trust mechanics, except my neighborhood one (who has since closed down shop after he died and his son did not want to continue running a mom-and-pop tranny shop) but oh well! My throttle cable goes across from the left hand far corner across to the right hand (behind the battery) next to the vacuum manifold. I tried looking today but could not figure out. Would you be able to give me a bit more description (or maybe a picture if you come across one)/. I really appreciate your help.
BTW, what would the mechanic try to "compensate" by increasing the throttle? I am very curious now.
Thanks Pedro.
Old Jun 23, 2009 | 06:02 AM
pedro's Avatar
Rough idle he can't fix.
Old Jun 25, 2009 | 10:11 AM
bingroy's Avatar
Thanks Pedro. I will locate the screw you mention and try to decrease the base RPM. If I cannot, I will take it to the mechanic... if no one can, I will come back to the forum....
L4Daddy
May 11, 2011 06:12 PM
L4Daddy
May 9, 2011 08:14 PM
ani
Feb 5, 2011 11:22 AM
bingroy
Jul 15, 2009 09:30 PM
arrowdragon
Aug 26, 2008 11:26 AM
