Door unlocks automatically
Old Jan 28, 2011 | 04:22 PM
txstcamry's Avatar
Default Door unlocks automatically
Have a 93 Camry LE, power doors began unlocking by themselves, also radio and clock don't work. Locks won't stay locked. Any ideas???
Old Jan 28, 2011 | 08:04 PM
Radio and clock may share a common fuses. Check CIG/Radio and Dome fuses.
Check the doors switches.
Sometimes the wiring to the drivers door console and going from the door to the chassis can break down due to flexing causing door lock problems.
Old Jan 29, 2011 | 11:22 AM
txstcamry's Avatar
checked fuses seem okay
all this happened at same time
Old Jan 29, 2011 | 11:48 AM
These are completely different circuits.
Power to the fuses above comes off the ign switch, check for power at the fuses.
Old Feb 5, 2011 | 05:12 PM
brianjrealtor's Avatar
I had this same problem...
all the wire leading from the drivers side door into the cabin wore out over time with all the open/shuting of the drivers door.
I had to splice all the door speaker and doors control wires and connect them back together. it's a small space to work within, but it can be done with patience. you also don;t have much wire to work with and be able to splice to put back togetther.
i ended up getting some extra wire to splice each end and use as a "bridge" to connect to each end. of the stock car wiring. used the heat-shrink wrap to seal each wire after spling and connection everything..
just make sure you have the heat shrink tube on first before twisting the wires back together so you can heat it up after each re0-connect!
demiandvm54
Jul 6, 2021 07:40 AM
jjadus
Jan 6, 2011 09:50 AM
eilros
Nov 13, 2007 09:00 PM
cmrylovr
Jul 30, 2006 05:10 PM
rpunit
Jan 25, 2006 08:41 PM
