Electrical issues or something else going on?
Old Sep 9, 2022 | 08:04 PM
Fly_22043's Avatar
Default 2010 LE: Electrical issues or something else going on?
Hi
When I try to lock the door using the lock button, it locks the door and immediately reverses. Having similar issue with the power window button. When I use the window button, window goes up and immediately reverses. What could be wrong?
Thanks
Old Sep 9, 2022 | 09:05 PM
Year of car?
Old Sep 9, 2022 | 09:15 PM
Fly_22043's Avatar
Default 2010 Camry
Thanks
Old Sep 10, 2022 | 04:34 PM
Year of car?
Old Sep 10, 2022 | 07:27 PM
Fly_22043's Avatar
I already responded with the year. It’s 2010 Camry LE. Not sure why you are not able to see it. I can see it. New to the group so not sure what could be the issue.
Old Sep 11, 2022 | 12:44 PM
You modified the title rather then list the year in a response.
Do all of the windows have the same reverse problem when you try to raise them?
The windows have feature that reverses them to prevent say someones head from being trapped.
The door locks will lock/unlock if a door switch is not closed (the bad switch simulates an open door).
Old Sep 11, 2022 | 01:37 PM
Fly_22043's Avatar
The problem happens intermittently with the window reversing after going all the way up. Locking all the doors from the button inside also reverses and unlocks for both the driver and passenger side.
The remote key doesn’t lock or unlock and none of the features work.
Just now I took the car for alignment. Everything is working for now! How is that possible? I checked with the mechanic and he said nothing they touched impacted the door, lock or the windows!
Your thoughts?
Thanks
Old Sep 11, 2022 | 03:21 PM
Don't know.
A dying remote battery can cause issues.
There is computer that controls the locks and windows. Perhaps it has an intermediate problem.
Old Sep 11, 2022 | 06:40 PM
Fly_22043's Avatar
The remote battery is brand new. First thing I did when I started having the problem. Besides, I’m not sure why the battery on the remote would impact the lock button on the driver or passenger door or even the button for the windows.
Thanks
Old Sep 11, 2022 | 06:42 PM
Fly_22043's Avatar
I thought maybe the fuse 30a is dead causing the issues. That will be my next check if the problem happens again. Thanks
jmac247
Apr 13, 2022 08:08 AM
glaze417
May 2, 2014 09:54 AM
linsjean
Apr 6, 2012 08:55 AM
mx3man83
Jul 4, 2009 11:24 PM
rjp
Mar 19, 2007 10:53 PM
