Foggy windshield & windows
Old Dec 13, 2015 | 06:44 PM
gnx547's Avatar
Default Foggy windshield & windows
On my 97 Camry, the windshield and windows fogs up a lot. The windshield and windows are always foggy when it is cold outside or when it rains. I have the defroster & heat on and it does not help out a lot. It is sometimes so bad that I have to wipe with the windshield and windows so I can see. Any ideas why the windshield and windows always fog up so bad?
Old Dec 14, 2015 | 02:18 AM
dirty hands's Avatar
I forget the science theory for it
The inside temp of the car is colder than the outside temp
or the other way around
So it fogs
Sometimes air con directed onto the windshield can clear fog quicker in rainy conditions..than the heater
Old Dec 15, 2015 | 01:36 AM
Yes, turning on the AC with defrost should make short work of a foggy windshield.
Be sure that your floor boards are nice and dry and that there is no water leaking into the car.
My A/C drain tube got pushed up through the floor board and the unit would drain condensation onto the passenger side foot well. The carpet got soaked and the windows would fog up in the heat.
Old Dec 16, 2015 | 09:07 AM
gnx547's Avatar
Unfortunately the AC does not work. I added some freon and the AC is turned on but the clutch doesn't come on. About how long does it take for the clutch to cycle? Should it cycle when the freon is being added?
Old Dec 16, 2015 | 04:48 PM
If the clutch is not engaging
Not enough gas pressure in the sealed system
Leaks ?
Or the clutch ac /compressor
has a problem
Maybe time for a A C workshop inspection to sort it out
Old Jan 30, 2016 | 09:01 PM
gregs396's Avatar
I have found that the water that commonly builds up in the LH side well of the trunk can be the cause. Check to see if you have any water in that area, if so punch out the drain plug and leave it out. Does your car have a sunroof? If so, the drain can get clogged and leak water onto the floor.
dwm1225
Aug 13, 2015 10:53 AM
gorak
Feb 26, 2010 07:51 PM
952DRCamry
Mar 22, 2009 11:49 AM
Player
Dec 3, 2008 06:03 AM
Player
Nov 27, 2008 01:17 AM
