How to tighten PS belt?
Old Jul 17, 2006 | 12:07 AM
sl1solo's Avatar
Default How to tighten PS belt?
i just replaced my belts and it seems my Power steering belt slips and makes a VERY loud and annoying screeching noise on 4k+ RPM is there any way to tighten this thats possible? not alot of wiggling room around there...
Old Jul 17, 2006 | 03:52 AM
Joel_CA's Avatar
Default RE: How to tighten PS belt?
It's best done down from the wheel well where there's a bunch of room. Once the spash shield is off, just loosen the adjustment lock bolt, use a prybar between the block and the power steering pump to tighten the belt slack- then lock it back down. This applies to both the V6 and the 4cyl Camry.
J
Old Jul 17, 2006 | 10:17 PM
sl1solo's Avatar
oh and thats with the apron off right?> a bit tight in there with y 5sfe but i guess with some short ratchets it can be done. So let me get this strait:
Old Jul 18, 2006 | 04:36 AM
Joel_CA's Avatar
Loosening the adjustment bolt is all you'll need to do after taking the apron off. From there, you can use a prybar to push the pump outwards to apply more tension to the belt.. then retighten it. Good Luck! Excellent illustration btw!
Joel, CA
paulm
Jun 24, 2015 10:08 AM
hardyrxp
Feb 17, 2010 10:45 PM
hardyrxp
Feb 2, 2010 09:14 PM
hardyrxp
Feb 2, 2010 07:07 PM
