hydraulic cooling fan
Old Nov 26, 2005 | 02:18 AM
camryshy's Avatar
Default hydraulic cooling fan
i have a 93 camry 3.0 and i have 10.5 volts going to the coolant temp sensor.needless to say it won't start. at the data link connector when i jump the terminals E1 and OP1 the fan does not run. at the cooling fan ecu plug when i go from terminal 1 to ground it should be battery voltage but i have none. at terminal 5 to ground i have continuity with the throttle open or closed. at terminal 8 it operates as it should with the ac pressure switch. the resistance between terminals 2 and 3 is ok. i have cleaned up the ground wires and replaced the ecu with one from junk yard off a working car, any help is greatly appriciated.
Rainman65
Jul 21, 2015 01:38 AM
ghettoshelf
Jul 25, 2014 05:40 PM
spaghetti
Jan 10, 2014 05:36 PM
RWS
Dec 31, 2008 09:37 PM
alex
Aug 20, 2007 07:13 PM
