Intermittent starting problem
Old Aug 13, 2007 | 11:58 PM
89cam's Avatar
Default Intermittent starting problem
I have an 89 camry with 185K miles and have recently experienced the following problem. When turning the key to start, nothing happens. All ignition and dash lights illuminate normally but the starter will not turn. I cleaned all the starter and battery connections, and went as far as cleaning the rotary ignition contacts in the steering colum. This problem occurs intermitttently, when car is hot and cold. When it does crank, it turns over strong and starts right up. I suspect a starter relay but I'm not sure where its located. My local tech thinks it might be the starter and that the relay is located in/on the starter? Any suggestions??
Old Aug 14, 2007 | 11:16 PM
toyoboy's Avatar
Default RE: Intermittent starting problem
alot of times its the starter contacts....next time the starter acts up try lightly tapping the starter with a hammer and see if it starter up...
kittster
May 21, 2014 12:50 AM
Debunker
Dec 12, 2013 11:01 AM
FGCUHank
Sep 21, 2012 08:22 AM
K9AMRee8
Feb 4, 2008 05:39 PM
kirubel98
Aug 22, 2005 05:38 PM
