Keep losing power to charging ports
Old Aug 18, 2015 | 07:13 PM
KurtI's Avatar
Default Keep losing power to charging ports
Hello,
I have a 2008 Hybrid and the fuse for the charging ports keep blowing. I've replaced that fuse 10 times or more with in the last 2 months. I've tried 5 different cell phone chargers and all of them will blow the fuse. I'm at a loss as what is blowing this fuse. Please help. Thanks
Old Aug 18, 2015 | 10:21 PM
What size fuse are you using?
Does the car have two power outlets, if so what is plugged into the other one?
Old Aug 19, 2015 | 07:23 AM
KurtI's Avatar
Default Nothing plugged in.
There's nothing plugged in to the other port. Some phone chargers blow the fuse faster than others.
Old Aug 19, 2015 | 07:09 PM
Others have had the same issue.
Might look at the charger plug and power socket to determine if it is possible for the two could cause a short when mated together.
Examine the power port for any bits of metal that might have falling in.
Old Aug 19, 2015 | 09:19 PM
KurtI's Avatar
I've checked for something falling into ports. Found nothing. Checked for dead shorts, nothing. Seems like it just can't handle the amps
Thanks
Old Aug 20, 2015 | 11:58 AM
Thought the fuse is 20A which is a LOT! The power consumption of the charger might be around 700ma.
Have you tried using the other port?
My guess is the issue is with the power port. Perhaps other chargers have slightly different plugs that work somewhat better with the port.
Old Aug 20, 2015 | 12:21 PM
KurtI's Avatar
500 mha charger will blow the 20 amp fuse in 6 hrs. I'm gonna try and pull the ports as look at connections.
DIYDad
May 10, 2019 02:47 AM
Toyfire
Oct 8, 2011 03:53 AM
rolo12543
Dec 31, 2007 09:15 PM
slippin2
Oct 2, 2007 09:50 PM
Apexs20s
Apr 12, 2006 03:48 AM
