Need Help BMC
Old Apr 9, 2010 | 06:23 AM
Twenty4seven's Avatar
Default Need Help BMC
Hi there all,
im from the netherlands, and i've got a problem, like many others :P
and like other dutchs forums are useless so i came down here
Yesterday i wanted to repair the brake master cylinder off an camry 1998 with the 2 bolt pattern. Primary piston was stuck.. but went out after filling with wd40, but the second also came out in parts :S ( not broken ) i did make picture on the first piston but i do not know how the second piston looks like.. because the camry bmc looks diffrent then many others i would like to know if somebody knows how it needs to look when assambled :P
Please help.
Reynier
Old Apr 12, 2010 | 08:52 AM
Lincoln's Avatar
Default RE:Need help BMC
I think guys you should to change both piston and install by a expert person those who know about engine and professional garage they can solve your problem. Iim sure then after your piston will not easily stuck .
All the best !
rlmeredith
Aug 21, 2012 07:33 AM
sv21
Apr 30, 2009 12:52 PM
ToyotaMan55
Jun 6, 2006 01:51 PM
SymtecX
Feb 27, 2006 03:00 AM
cam03TRD
Aug 21, 2005 06:55 AM
