odd idle problem after running 55mph
Old Mar 17, 2013 | 04:17 PM
pauloil's Avatar
Default odd idle problem after running 55mph
had no idle and had to goose the gas pedal in neutral to keep motor going after slowing down after a 12 mile interstate trip. got to my destination, and after a cool down of 45 min, everything was back to normal. no CEL. ideas as to what happened?
Old Mar 17, 2013 | 04:27 PM
pauloil's Avatar
2001 4 cylinder
Old Mar 17, 2013 | 06:47 PM
Other then the no idle issue did the engine operate OK? No hesitation, miss, lack of power, etc?
Idle speed is controlled by the IAC valve. An internet search on "IAC" valve will generate hits on how it works.
If just an idle speed problem the valve could need cleaning.
Or the EGR valve might have stuck open. If open, the engine will want to quit at idle speeds.
Old Mar 17, 2013 | 09:49 PM
pauloil's Avatar
car runs fine. I was thinking of cleaning IAC, but thought that was more for cold starts.
I will consider egr clean also.
Old Mar 18, 2013 | 10:34 AM
If the engine runs OK but will not hold idle check IAC valve. The valve is used to control idle RPM engine hot or cold. You need not take the valve apart to clean it.
The internet has many post on cleaning the IAC valve.
carlos1787
May 23, 2009 05:57 AM
wanderingsoul
Jan 19, 2009 05:11 PM
socal pat
Jan 19, 2009 04:47 PM
burkej62
Jan 29, 2008 10:06 PM
marc780
Apr 10, 2006 06:22 PM
