Poor Fuel Mileage....
Old Oct 25, 2015 | 11:03 PM
jmrgn59's Avatar
Default Poor Fuel Mileage....
I can use some ideas! I have a 2003 Camry 4cyl with 97K. I recall getting very good gas mileage when I bought it some 5 years ago. The fuel mileage seemed to have decreased fairly suddenly. I am now getting 18-20 mpg around town and 22-24 highway. I have changed plugs ( iridium ), both oxygen sensors, cleaned MAF sensor and throttle body. Scan tool shows no codes. I'm sure it should be getting better fuel mileage. Any ideas would be greatly appreciated. Thanks.......
Old Nov 3, 2015 | 02:16 PM
Are you using the cars MPG computer to determine MPG? If so determine MPG by gallons filled and miles.
Has the gasoline fuel mix at the pump changed, as in more ethanol for winter usage? This can drop MPG.
Try another gas station/brand as the station may have changed the mix without stating so, or is are now receiving fuel which is not blended properly resulting in more alcohol.
Might check the coolant temp sensor for computer. If bad the engine can be stuck in cold operation mode.
Old Nov 5, 2015 | 12:36 AM
coldburn92's Avatar
To remind you some common habit of better driving like hypermilling and making sure the correct tire pressure, these always makes a difference.
happyhauss
Sep 15, 2022 02:29 PM
natemoore
Jul 7, 2013 08:21 PM
AmiRon
Jan 15, 2012 09:33 PM
Maineguy
Nov 20, 2009 09:36 PM
wongleetoy
Aug 11, 2007 06:11 AM
