Power steering issue
I have a 1989 Camry and i'm losing fluid. Think I've traced the leak to the line from the pump. It has a banjo fitting on one end a female threaded end on the other.
Looks fairly simple to replace....
Any suggestions or tips?
Thanx in advance!
Thanx in advance!
Is the leak from a location that is damaged such as where the fitting is swagged to the hose or a loose fitting that can be repaired?
Make sure to replace the crush washers on the banjo fitting.
To bleed the PS system turn steering wheel lock to lock a few times.
