Starter Noise
Old Nov 25, 2006 | 11:57 PM
greenfire's Avatar
Default Starter Noise
About every other time I start the car, the starter will make a loud grinding/rattle type noise and the car will not start. Second try.. it will start up fine. I assume this is bad starter, but before I replace it could I be overlooking another problem??
Old Nov 26, 2006 | 10:52 PM
lavalleemike's Avatar
Default RE: Starter Noise
you may also be missing a tooth or two on your fly wheel
Old Nov 28, 2006 | 09:30 PM
greenfire's Avatar
Well I replaced the starter... to find out that was not the problem. I think the igintion is sticking sometimes and the starter continues to spin.
Old Nov 28, 2006 | 11:15 PM
the igniton is no fun to change i assure you
Old Nov 28, 2006 | 11:41 PM
greenfire's Avatar
Well it seems if I release the key quickly when starting its fine! In other words I can't hold the key on start longer than one second. Fortunatly the car starts up no problem. Looks like I may have dodged another bullet (at least for now). I wish I didnt waste money on that starter though. It cost me 1/6 of what the entire car cost [:@]
Old Nov 30, 2006 | 09:10 PM
greenfire's Avatar
Mike could you tell me more about this flywheel and where it is located... The problem is getting worse. The starter is not catching.
ToyCamry99
Jun 6, 2007 07:26 PM
PeterUbers
Mar 19, 2007 04:41 PM
jupitor2
Nov 25, 2006 10:50 PM
Pele
Jun 20, 2006 02:56 AM
FishyMan
Apr 4, 2006 08:45 PM
