starting problem
Old Apr 16, 2006 | 10:23 PM
perdian's Avatar
Default starting problem
I have a 96 Camry which I disconnected and removed the battery while I was on vacation for three weeks. Upon re-connecting the battery the engine now will not start? All the electronics work - horn will go off when I open door until I disconnect battery again, but engine does not crank over. Any suggestions.
Thanks
Old Apr 17, 2006 | 03:32 AM
marc780's Avatar
Default RE: starting problem
Check the battery. Have it charged and load tested. You probably need a new one? Battery lasts longer when kept at full charge so it was probably weak to begin with for just sitting idle to be the cause of killing it.
If you leave it sitting a lot i recommend a solar charger. I got mine $20 from Kraegen. It can overcharge unless you buy the seperate regulator (another $30 no thanks) so i leave my charger sitting on the seat. Works pretty well.
Old Nov 25, 2006 | 10:52 PM
toyotaadvisor's Avatar
more than likely you have triggered your anti-theft system. do you have a remote key pad?
Old Apr 22, 2007 | 10:41 AM
weatherman1400's Avatar
say more please about the anti-theft system.
Old Apr 22, 2007 | 10:42 AM
How do you solve the anti-theft system issue?
alistaircookie
Dec 15, 2011 09:37 AM
beaches
Jan 17, 2009 06:53 PM
sposey
Oct 25, 2007 09:22 PM
89cam
Aug 14, 2007 11:16 PM
cardman
Nov 24, 2006 04:25 AM
