Timing question
Hey Just purchased a 1996 Camry with the 5S-FE. I am having trouble with low and searching idle. I have cleaned Throttle body and IAC valve. But still searching for idle. I pulled timing cover to check timing marks and am a bit confused about which mark I should be looking at on Cam housing/Bearing. I am currently lined up with a slash in the houseing @ about 11 oclock. There is another mark @ 9oclock that looks like a drill mark. So which mark do I line up on cam the 11 oclock "|" mark or the 9oclock "*" mark? Thank you! Michael
