Transition to led headlamps
Old Dec 28, 2021 | 08:24 AM
Lorenc's Avatar
Default Transition to led headlamps
A few months ago I purchased lasfit led headlamp bulbs to replace the halogen bulbs on my 2015 Camry SE. I like the led bulbs but the drl/high beam bulb flickers during the daytime. I know it’s a power issue. I purchased and installed a canbus per lasfit, now I have no drl. The high beams still work. Lasfit said that the canbus disabled the drl. Is there any led bulbs that I can use that won’t flicker when using the drl. Thanks
Old Dec 28, 2021 | 01:21 PM
Is the bulb the same for DRL and headlights?
You may need something like in the link below but street legal.
https://allalighting.com/products/h8...ing-lights-drl
The issue may be the voltage to the bulbs when the DRL is on is less then 12V to dim the lights. This is OK with a filament bulb but doesn't work with most LED bulbs. Most LED bulbs are either 100% on or off.
Old Dec 28, 2021 | 02:37 PM
Lorenc's Avatar
Yes it is one bulb for drl and high beams
Old Dec 28, 2021 | 06:12 PM
The DRL operates by lowering the the voltage to the bulb to dim the output. This works in filament bulbs but not with LED unless they are constructed to be dimmable.
You need to find a headlight LED bulb that is dimmable..
Old Mar 27, 2022 | 03:31 AM
derisolx's Avatar
I'd like to see some kind of regulations for LED's. When I am driving, even in the daylight, I am blinded by LED's, they are just plain too bright unless carefully aimed to prevent blinding oncoming traffic. They used to check headlight aim back when they did auto inspections, but now that they stopped do that it's terrible out there. I suppose a certain number of people will need to be killed in accidents before something is done about this problem.
snaptube vidmate
Old Apr 26, 2022 | 04:59 PM
06XLE's Avatar
Anyone figure out how to make the DRL lights work with LED bulbs? I have 2006 camry. Just installed LED 9005 and 9006, now my DRL do not work. Any ideas?
srjacob99
Apr 1, 2015 10:33 AM
carid
Oct 17, 2014 05:19 AM
N3FOL
May 22, 2014 10:16 PM
mpz080808
Jul 11, 2010 04:56 PM
camry313
Apr 12, 2007 01:54 PM
