Transmission fluid
Old Jul 15, 2019 | 11:28 AM
Bberls's Avatar
Default Transmission fluid
97 v6 camry le. Want to change transmission fluid but not sure what brand/type to use. Says to use dexron iii but no longer available. There are conflicting opinions at auto store as to which one is right for the car. Any thoughts?
Old Jul 15, 2019 | 03:59 PM
Look for something called Dexron III/Mercon, Dex/Merc, Import MV ATF, MD-3.
What auto store did you go to?
Old Jul 15, 2019 | 05:12 PM
Bberls's Avatar
I went to autozone. But I finally found it in parts authority. Tx. My shift solenoid e code is coming up. The tranny fluid is black. Do you have an opinion on changing filter and fluid?
Old Jul 15, 2019 | 08:37 PM
Are you going to keep the car?
Black is not good. Change all the fluid as per the method in a post I made to site on Sunday.
Solenoid could be a separate issue.
Old Jul 15, 2019 | 09:12 PM
Bberls's Avatar
LInk to that post?
Corvstang
Jan 31, 2019 10:49 AM
krenekj
Jan 26, 2018 01:57 PM
imabadczech
Dec 10, 2012 08:22 PM
melahi
Jun 20, 2008 09:49 AM
72AMX
Feb 22, 2008 05:59 AM
