2001 camry le 2.2 fuel pump problem
Old Jan 15, 2022 | 03:59 PM
ROYTOYOTA's Avatar
Default 2001 camry le 2.2 fuel pump problem
i haave a problem with my fuel pump ......when i turn the key on there is no noise coming from the pump, but when i hook my scanner up to it and activate the fuel pump it works!?? My relays are working but there is no voltage going to the pump......any ideas
Old Jan 15, 2022 | 07:43 PM
The pump only operates when the engine is cranking over to start or running.
Old Jan 16, 2022 | 12:55 PM
ROYTOYOTA's Avatar
TY for replying Toyomoho ,doesn't the pump turn on a couple of seconds before cranking to pressurize the system
Old Jan 16, 2022 | 03:05 PM
Pump only turns on as specified previously.
The system has a check valve that prevents bleed down when off. However over time the system can pressure can drop. Typically re-pressuring the system is not a problem when starting. Cars sitting for months and months start right up.
Dudley29
Jul 25, 2021 09:34 AM
jessicaD
Aug 25, 2017 12:38 PM
Ken.2003
Oct 24, 2015 11:35 AM
PYRO
Sep 29, 2011 05:01 AM
lance
Feb 2, 2009 04:29 PM
