Climatic control lights,hazard control light switch and gear shift light
Old Jan 15, 2022 | 04:47 PM
Victt's Avatar
Default Climatic control lights,hazard control light switch and gear shift light
Hi people,
I'm having problems with lights of all 3 below.
Climatic control lights,hazard control light switch located center dashboard and gear shift light light (P,R,N,D)doest light up. Could there be a solution for I know its not a bulb issue. Changed a while climatic control panel and nothing changed. Didn't want to waste money on other once for o dont know what is wrong.
can someone help.
Thanks in advance
Old Jan 15, 2022 | 07:42 PM
Year of car and engine type?
Old Feb 9, 2022 | 09:32 PM
Victt's Avatar
Hi sorry for replying at this time . been hospitalized.
The car model and type is a Toyota Camry 2007 Le . 2.4fe engine 4cylinder
Thanks
Old Feb 10, 2022 | 03:59 PM
Trust your doing OK.Is one of the non working lights the A/C climate light controls?
It appears the problem lights have a common fuse 7.5A PANEL fuse.
The lights have a common ground buss. Note that light operation is controlled by grounding the lights to complete the circuit. The ground wire runs thought the instrument console for what might be dimmer control.
When the taillight relay is powered, the lights have power. Check for power at the bulb when the headlights are on.
Check the chassis front side marker lights for operation as they receive power from the same taillight relay as the Panel fuse.
eggochico
May 22, 2021 03:56 PM
workwork
Dec 11, 2020 12:47 PM
KAM712TOYOTA
Jun 3, 2019 12:33 PM
utslerfamily
Jan 23, 2019 12:45 PM
ll5175
May 21, 2008 08:37 PM
