Gear indicator lights on instrument cluster
Old May 19, 2021 | 12:19 AM
eggochico's Avatar
Default Gear indicator lights on instrument cluster
Hi! The gear indicator lights on the instrument cluster of my 1995 Camry LE are newly replaced but some lights, particularly the most used R and D, would light up intermittently whenever i shift gears. Is there something that needs to be cleaned or fixed in the contact points of the shift **** mechanism itself? Please advice. Thank you!
Old May 22, 2021 | 03:56 PM
The lights are controlled by a rotatory switch located on the trans housing gear shift lever output shift. Each light has its own switch contact.
The switch could be the problem or wiring. If you think it's the switch replace it or clean the contacts. There may be links on the internet about how to disassemble and clean the contacts or at least be able to inject contact cleaner.
Christi
Jul 25, 2020 08:49 PM
terimaggio
Feb 11, 2019 03:30 PM
Raney
Oct 27, 2012 12:16 PM
Emad
Jul 5, 2011 11:14 AM
jlouis69
Jan 4, 2009 09:57 PM
