Having trouble replacing ps belt 2002 v6
Hi Folks,
First time posting to the forum. Own a 2002 Camry XLE 3.0L V6 w/ 90K miles. No problems to report other than what some of you experienced over the years, i.e., e.g. warp rotor TSB issue, engine/trans mounts. Decided to replace the AC/Alt and PS belts this weekend. I've worked on a lot of different vehicles for many years, but I never had so much trouble with replacing a PS belt!
Removed front RH wheel, apron cover, etc. I can see and get to the adjusting bolt, but I cannot believe - if I am reading the manual correctly - that I have to remove the pressure tube, etc. to access and loosen the second [pivot] bolt??!!! I cannot even see where I can place a pry bar to loosen the belt tension...
Anyone ever come across this?? Special tools required?
Anything you can provide is appreciated. Thanks!
redman1118
Jan 25, 2010 07:13 AM
