hazard lights turn on when using turn signal
Old Mar 14, 2021 | 11:06 PM
h3xrsc's Avatar
Default hazard lights turn on when using turn signal
Recently my hazard lights started to turn on whenever i try to use the turn signal , i havent tried anything because i dont know where to start, anyone experienced this? please help
Old Mar 15, 2021 | 07:59 PM
You sure the hazards are on or are just both turn signals are now working at the same time, there is a difference.
Year of car?
Could be a bad switch.
Old Mar 18, 2021 | 09:58 PM
h3xrsc's Avatar
yea they both go off at the same time, 2002 camry LE 2.4
Old Mar 18, 2021 | 10:16 PM
The turn signal switch on the steering locum could be bad. Youtube should have videos on replacing the switch..
Old Mar 22, 2021 | 03:10 AM
h3xrsc's Avatar
i mean they both flash at the same time when i hit the switch to go L or R, i purchased the flasher relay but your saying the switch ?
Old Mar 22, 2021 | 06:31 PM
The flasher is wired in between the power source and turn switch. When the turn switch is moved it sends this on/off power (flashing) to either the L or R turn signal bulbs. Given the flasher is ahead of the turn switch not sure how it could cause both L and R turn signals to work.
Old Mar 24, 2021 | 08:53 PM
h3xrsc's Avatar
could it be the flasher relay ?
Old Mar 25, 2021 | 05:43 PM
Doubt it but since you have a new relay try it.
Jeipuri
Aug 16, 2020 03:45 AM
terimaggio
Feb 11, 2019 03:30 PM
Cambodiacamryowner
May 15, 2017 03:16 PM
wmedani
Apr 9, 2012 09:03 AM
music479
Nov 24, 2008 10:02 AM
