Sights n Sounds Post your video clips here.
Name that sound!
Old Aug 2, 2023 | 12:20 PM
3PedalJones's Avatar
Question Name that sound!
2004 Camry with the 2.4L 2AZ-FE engine. Almost 120k miles on it with only a water pump replacement 4 years ago and regular maintenance otherwise. Car has started making a “squeaky rattle” just off idle, which is audible in the video. (Car idles smoothly - that’s just my wife lightly stabbing the throttle to generate noise.) Thought it might be an exhaust leak, but everything seems tight, and I would think the noise would continue under acceleration but it’s only when you first hit the gas. Anyone else have suggestions or history with a similar noise issue? Thanks in advance.
(attached movie with audio in third post below)
Old Aug 2, 2023 | 02:15 PM
For unknown reasons the file is failing to download.
Old Aug 2, 2023 | 03:09 PM
Thanks - trying to get a corrected file uploaded.
Old Aug 2, 2023 | 04:49 PM
Default Video attempt #2
See if this works this time.
File Type: mov
Old Aug 3, 2023 | 07:13 PM
The noise is loud enough. Use a section of hose as a stethoscope to narrow down the location. Once narrowed down take a photo of that area. Make sure to check the engine air intake manifold area.
Old Sep 9, 2023 | 12:04 PM
Default Found it
Finally tried the hose/stethoscope method, still couldn't quite isolate the source of the noise. Gave a closer visual inspection while running and noticed a very slight wobble in the accessory belt tensioner. Put a pry bar up against the pulley bolt and it seemed to quiet down slightly. So, I put a new belt and tensioner assembly on it - bingo! Nice and quiet again. Funny thing is, the old tensioner assembly feels pretty tight when trying to move it around by hand, but I guess with the stress of the belt on it the bearing was starting to fail.
Old Sep 9, 2023 | 11:50 PM
Great job!
Curtis66
Feb 4, 2022 10:57 PM
thecamryway
Jun 22, 2020 01:38 PM
Adam Ramsdell
Jan 17, 2017 01:58 PM
leon_nerd
Jan 13, 2013 06:18 PM
ninas
Mar 11, 2007 05:44 AM
