07 Camry Strut and Strut mount Problems
Old Jan 25, 2010 | 07:30 PM
turtle02909's Avatar
Unhappy 07 Camry Strut and Strut mount Problems
Does any one has the fix for this annoying noise from the driver side strut locations? The car ride like is on it bump stop and every pot hole I drive over make a popping noise and the ride is harsh. I also notice on highway speed between 65-75 my front end shake a lot. I can also feel it in the gas peddal. My car is cover under warranty but it does not cover the struts. If I had known that I would never bought the car.
I am planning to get after market struts. Does anybody know if I should replace the strut mount and strut bearing at the same time as the strut? Every help with this is appreciated.
Old Jan 25, 2010 | 09:21 PM
There is a TSB for this year of car concerning steering wheel flutter and vibration at the speeds you posted. See link below:
http://www.allworldauto.com/tsbs/NHT...in_272466.html
Check the link below:
http://www.toyotanation.com/forum/sh...d.php?t=258094
Knocking from the front suspension is typically a bad upper strut mount or sway bar bushing.
Seldom to the struts go bad and result in noise or driving problems, they can leak but you should be able to see this on inspection.
Galen Snyder
Aug 13, 2014 12:55 AM
strausbo
Dec 21, 2011 09:01 AM
Lunareclipse02
Sep 29, 2011 10:09 PM
zcpro
May 26, 2009 12:10 PM
sgani
Jan 2, 2009 07:47 PM
