Camry 2013 Steering Return Problem
Guys,
Hi,
I am new to this forum, greetings to all.
Actually I have a problem in my Camry 2013, When I am turning my steering it is not returning automatically. I mean steering return doesnt feel like it has power, I need to push a little to start a motion to return to normal position.
Can anyone assist me on this problem.
Hi,
Is this a recent issue?
Did the car hit something, a curb, pot hole, etc. Any front end work done on the car such as new brakes, tires, etc.
How is the front tire pressure?
Is the steering warning light icon on dash illuminated?
Bro,
Thanks for the response.
No its from day one since I bought the car.
I suspected it was due to damaged tie rods, balancing rods or shock absorber mount. I got them replace all, but still the problem is there.
Tyre pressue is equal in all four tyres, its around 28 psi.
I will try to make a video and send to you, about the car behavior.
No illumination on information cluster.
Did you buy the car new or used?
Typically the steering caster setting is responsible for straightening the wheels out after a turn. To adjust caster requires adding a caster adjusting plate.
Have you had the steering geometry checked? Toyota does list caster specs.
Have you tried swapping front tires?
erbrian
11-13-2016 01:36 PM
