Camry 2013 Steering Return Problem
Old Feb 5, 2018 | 02:27 AM
shahrar2002's Avatar
Default Camry 2013 Steering Return Problem
Guys,
Hi,
I am new to this forum, greetings to all.
Actually I have a problem in my Camry 2013, When I am turning my steering it is not returning automatically. I mean steering return doesnt feel like it has power, I need to push a little to start a motion to return to normal position.
Can anyone assist me on this problem.
Old Feb 5, 2018 | 11:15 AM
Is this a recent issue?
Did the car hit something, a curb, pot hole, etc. Any front end work done on the car such as new brakes, tires, etc.
How is the front tire pressure?
Is the steering warning light icon on dash illuminated?
Old Feb 11, 2018 | 01:58 AM
Bro,
Thanks for the response.
No its from day one since I bought the car.
I suspected it was due to damaged tie rods, balancing rods or shock absorber mount. I got them replace all, but still the problem is there.
Tyre pressue is equal in all four tyres, its around 28 psi.
I will try to make a video and send to you, about the car behavior.
No illumination on information cluster.
Last edited by shahrar2002; Feb 11, 2018 at 02:07 AM. Reason: adding some comments.
Old Feb 11, 2018 | 10:50 AM
Did you buy the car new or used?
Typically the steering caster setting is responsible for straightening the wheels out after a turn. To adjust caster requires adding a caster adjusting plate.
Have you had the steering geometry checked? Toyota does list caster specs.
Have you tried swapping front tires?
cherrmj
Nov 22, 2016 06:53 AM
erbrian
Nov 13, 2016 01:36 PM
mycarcamry
Feb 17, 2013 10:00 PM
Player
Dec 3, 2008 06:03 AM
Player
Nov 27, 2008 01:17 AM
