Bend toe rod 2004 camry repair estimate $319
Old Mar 4, 2008 | 03:52 PM
hutington's Avatar
Default Bend toe rod 2004 camry repair estimate $319
Hi,
I bought a 2004 Camry LE few months back. I took it to a garage to fix a transmission leak problem. The mechanic showed me a bend toe rod in the left rear. He told it might be from a rock/curb hit (previous owner- oops I missed this point while buying). He says that this can cause misalignment of wheel and increase tire wear. (Though I do not feel any steering problems ). He gave me this estimate a) new toe rod -144 b) labor - 105 c) wheel alignment - 70.
My questions are
a) Is this repair necessary?. I mean will the situationdeteriorate if un repaired ?
b) Is this estimate reasonable?
Thanks a lot
[IMG]local://upfiles/5138/02B83005593B41B28F4A4FF7BA608C5C.jpg[/IMG]
[IMG]local://upfiles/5138/1548B71462F642E899A7AE69837F7931.jpg[/IMG]
Old Mar 4, 2008 | 05:47 PM
Default RE: Bend toe rod 2004 camry repair estimate $319
The issue would be abnormal tire wear. With the rod bent, the tire is no longer running straight but at a slight angle inwards at the front.
The rod is adjustable in length, might be able to lengthen it a little to compensate for the bend.
If you can find another rod, installation should be pretty straight for if you have a few tools. Something from a 2002-2006 car, try a junkyard.
Not up on the cost of a new part, the alignment cost is OK if for all 4 wheels.
Old Mar 4, 2008 | 06:25 PM
hutington's Avatar
hi toyomoho .. Thanks for the quick reply. I will try to get a rod from junk yard.
Field Allison
Mar 21, 2013 09:30 PM
filfoto
Mar 5, 2012 07:53 PM
pctechwright
Oct 25, 2011 07:14 PM
bigkev1
May 8, 2011 10:11 AM
csebes
Feb 5, 2009 06:26 PM
