Rotor replacement Camry LE How to remove
Old Feb 2, 2018 | 10:39 AM
Casmarzec's Avatar
Default Rotor replacement Camry LE How to remove
I tried to remove my rotors on my 2011 Camry LE. When I looked at YouTube the videos show nothing retaining the rotors when the tire and brake pad cradle are removed. While my rotor has a lot of rust, after I sprayed liquid wrench and banged on the rotor there is no movement. There is a nut on the center of the wheel, does it have to be removed?
Old Feb 2, 2018 | 04:37 PM
The center nut holds the axle to the hub bearing and hub.
There is nothing retaining the disk.
The link below provides a number of possible ways using common tools.
At Grommit's garage: Removing stubborn brake rotors
The best approach is an acetylene torch and heating the rotor around the larger center hole.
Next is a puller.
https://www.google.com/search?q=roto...rCX8_XJEZOcGM:
Old Feb 3, 2018 | 07:51 AM
Casmarzec's Avatar
Thank you. I found under the how to section that the rotor has two 8 mm holes that you put a bolt in and tighten. That worked with a pretty good pop. Lots of rust.
Old Feb 3, 2018 | 01:39 PM
Great job.
XpPaul
Jul 15, 2014 10:10 AM
2wonder
Aug 11, 2013 06:12 PM
applepomme
Sep 15, 2010 08:29 PM
turtle02909
Jun 4, 2009 09:14 AM
srwhouston
Feb 12, 2008 07:09 PM
