2012 Camry cranks but won't start
Old Feb 11, 2025 | 09:48 AM
Oldsman350's Avatar
Default 2012 Camry cranks but won't start
My 2012 Camry all of a sudden won't start. I noticed a couple of times before this happened it ran rough at first on start up like it wanted to kill. Now anytime I attempt to start even with starting fluid I have no ignition. After leaving the key on the on-position I hooked up a code reader to it and it's showing a P0303 code. Code this be a camshaft position sensor that has failed and is preventing ignition? The car only has 75,000 miles on it as of now.
Old Feb 11, 2025 | 05:22 PM
P0303 is for a misfire on cylinder 3. There is a long list of issues that can generate this code.
The timing sensor code is different. A bad sensor could cause the engine not to start. Any other codes?
Check for ign spark.
Old Feb 18, 2025 | 02:04 PM
Oldsman350's Avatar
No other codes present other than the P0303. I changed out camshaft position sensors and that didn't do anything. I'm going to check for spark this evening, if I get spark what should I check next?
Old Feb 18, 2025 | 06:30 PM
Oldsman350's Avatar
@toyomoho I checked the spark today and its getting spark. Fuel would spray out of the open spark plug hole a bit when we turned it over. So its getting spark and getting fuel not sure what the next thing to check would be.
Old Feb 19, 2025 | 12:08 AM
Check the timing, at least rule it out...
Old Feb 19, 2025 | 12:35 PM
You did state you saw fuel but I would test the fuel pump for output and pressure. There may be a fitting on the fuel rail to hook up a gauge. Places such AutoZone my loan the tool.
A stuck open EGR valve can cause non-start.
Fharmon
Jun 4, 2023 12:44 PM
traviskx
Aug 21, 2019 08:45 PM
BigTone258
Aug 9, 2015 11:58 AM
rgus67
Mar 15, 2014 12:05 AM
TheGryme
Sep 7, 2013 02:10 PM
