Camry Gearboxes 1984-2014
Old 09-21-2014, 05:14 AM
dirty hands's Avatar
Default Camry Gearboxes and Engines 1984-2014 workshop PDFs as at sept 2015
UPdated Jan 2016 some links closed some others new
all engines in this new link
https://www.camryforums.com/forum/di...-2014-a-50782/
Reading for later @ toyota wiki
http://en.wikipedia.org/wiki/Toyota_...2.80.931986.29
Gearboxes ALL
For Four Cyl and V6 versions manual and auto
most of these gearboxes repair manuals in pfd can be found on the internet just takes searching
--covering 1983- 2014 hopefully
Write ups on removals and any corrections in this topic or new data welcome
Quote "toyomoho : Look on side of drivers door for sticker listing various items including trans model."
information in this topic will be from various sources ...
if you dont have the set up and special tools - gearboxes are best removed with the motor through the top
Toyota All gearboxes wiki -------In time all the correct camry ones will be identified
http://en.wikipedia.org/wiki/List_of..._transmissions
Contribution From toyomoho on Manual gearboxes
Quote
2002-06: 2AZFE was only engine option offered with stick which was model E351.
1992-2001: 5SFE model S51.
1994-2002: 1MZ-FE E351.
1992-1993: 3VZ-FE E53 (source Wikipedia).
1988-1991: 3SFE S51, 2VZFE E52.
1988-1990: 3SFE used E56F5 on 4-wheel drive Camry (All-Trac).
With minor exceptions info is from Camry factory shop manuals. Wikipedia has variations on this such as not listing E52 or E56F5.
Info is for US cars and does not Camry Solara.
"end quote "
Manual Gearbox Listing
1984 - 1994 Camry
S51- E52 and E56-F5 Clutch section 13 pages see attachment
S51-S53 .... 29 pages
http://bgbonline.celicatech.com/6g/t...0s53%20s54.pdf
1997-2001 Camry 1MZ-FE E153
[I]2002-06: 2AZFE was only engine option offered with stick which was model E351.
E52 4 pages april 2015 PDF link down or closed
have found a parts link Manual Transmissions by Unit Code: E51, E52, E56, E57: Manual Transmission Parts - Online
E56F5 missing link
E35[/B]1 -97 pages
2006–2009 Toyota Camry (XV40)
EB62
(no free pdfs --you can get basic car repair manuals )
2009–present Toyota Camry (XV40)
Wiki on The A series automatic trannys Camry
Toyota A transmission - Wikipedia, the free encyclopedia
A140E and A541E
115 pages http://www.turboninjas.com/camry/ax1.pdf
1983-2001 Camry
A540H-A540E. 200 pages http://shop.ukrtrans.biz/wp-content/...logs/A540H.pdf
A140L
102 pages
http://www.all-trans.by/assets/site/...oyota/A140.pdf
2 pages parts layout only
http://www.automaticchoice.com/uploa...ue/aw_a140.pdf
1985-1986 Camry TurboDiesel------( I didnt even know they made a turbo Diesel Camry )
4 Speed Hydraulic Controlled Automatic Transaxle (2-way overdrive)
Applications:
Wiki on all U series automatic trannys ....Camry....
Toyota U transmission - Wikipedia, the free encyclopedia
- In time all the correct camry ones will be identified
U140E and U214E 118 pqges
a zip kit info 8 pages http://www.abtomat.ru/img/cat/U140E-U241E-ZIP.pdf
U151E
2005–2006 Camry (V6) 24 pages
http://share.qclt.com/%E4%B8%B0%E7%9...nit/027013.pdf
U241E - 20 pages
2001-2009
http://share.qclt.com/%E4%B8%B0%E7%9...nit/029013.pdf
20 pages pdf
slow to download 168 pages pdf
http://shop.ukrtrans.biz/wp-content/...logs/U241E.pdf
U250E 8 pages
http://www.atraonline.com/gears/2009.../2009_1_18.pdf
U660E
8 pages
http://www.transtec.com/downloads/te...ota/B94734.pdf
4 pages pdf
http://natpronet.com/trans/U660.pdf
U760E FWD 6 speed
2010– Camry (I4)
parts list http://natpronet.com/trans/U660.pdf
P311 2007 Camry Hybrid -
CVT gearboxes require special oil ..clear to look at or green - not red - and labelled suitable for CVT transmissions only add the wrong oil and goodbye gearbox
when to change a CVT gearbox oil
found some information on CVT transmissions
CVT transmission oil change question
if the service book says nothing about a CVT oil change interval
kms or mileage is not used as a oil change interval guide
not a monthly or yearly time frame
the life left in the CVT transmissions oil is calculated by an oil test and scale % of deterioration
ask how much it is for a CVT fluid analysis ? to get its oils deterioration date
CVT type toyota boxes explained
30 minutes CTV trannys of all Camry/Prius /design of first second and third gen
File Type: pdf
Last edited by dirty hands; 04-26-2016 at 06:05 AM. Reason: found new automatic pdfs and fixed closed ones
Old 09-22-2014, 11:23 AM
Stickied this. Nice info, dirty hands.
Old 01-07-2015, 10:05 PM
Spidop13's Avatar
Cool I'll take a look
Old 01-08-2015, 04:20 AM
update early 2015
i havent found anymore information online to update this topic
Old 01-08-2015, 12:00 PM
Have you ever found any info about why some auto trans of the same model have raised letters on the case and others have stamped letters?
The used trans dealers list raised and stamped lettered trans of the same model separately for reason unknown.
Old 01-09-2015, 05:02 AM
I have been searching ever since that question was posted last year
its the same gearbox external and internal --as far i can see-- both bolt on
never see this before myself
I cant even get a picture of the two different cases to investigate
I can only speculate
a design change during the run of the box
- different alloys or case shell thickness modification ..that had to be casing specific
would have to chase down the suppliers of the gearbox- assembly plant records etc
Needs two different moulds and techniques on the same casing and gearbox design
raised lettering or stamped could be done anytime during the outer case forming
Old 01-09-2015, 10:40 AM
Perhaps a casting improvement change that included cast letters to eliminate stamping of ID. Or two different manufacturers, etc
It appears even used trans sellers don't what the difference is.
The issue is seekers of used trans don't know if one can be substituted for another.
Old 01-10-2015, 03:19 PM
Camry Transmission .in a 2003 camry .is the box the forum topic was about
https://www.camryforums.com/forum/di...ication-49847/
this particular box was used for years 2001 to 2009 in toyotas..thats a lot of years for any changes
I would say any U241E raised or stamped will have the same box internals and housing should bolt on
first time ever the raised letters have been raised in any forum
I found a repair manual for it today and added it to the list of auto boxes - 20 pages
also found this information online --mentions stamped boxes only a few times 9 pages pdf
2006 – 2009 ...
http://www.toyotapart.com/AUTOMATIC_...SB-0200-08.pdf
Old 09-05-2015, 03:39 AM
additions to research on camrys
Camry engines 1984-2014 workshop PDFs as at January 2016
forum link
Kilo1
06-27-2014 10:13 PM
Camry84
12-06-2011 08:46 PM
awcforever
04-11-2011 05:20 PM
ray
08-05-2010 08:43 AM
87ds
06-01-2007 04:09 PM
Quick Reply: Camry Gearboxes 1984-2014
