Old Aug 26, 2015, 01:59 PM
How-Tos on this Topic
Browse all: Lighting Guides
Print Wikipost
1998 camry dash lights..fuse???
Old Feb 26, 2013 | 12:07 PM
ghowsley's Avatar
Default 1998 camry dash lights..fuse???
1998 2.2 Camry automatic.
The tachometer light and the ac/heater DASH lights don't work. Is this a fuse problems or a bulb problem?
Thanks
Old Feb 26, 2013 | 07:43 PM
Check panel fuse.
Cig lighter and ashtray lights are on the same power junction with bulbs grounded to common junction.
Radio and glove box are on same junction as dash light with a common ground
If any of these lights work the fuse is OK.
If lights on the same junction work then junction power is OK.
Old Feb 26, 2013 | 08:06 PM
go-part's Avatar
Former Sponsor
Chances are it is a fuse that needs to be replaced.
If you can test the fuses that are under your dash.
Old Feb 26, 2013 | 09:38 PM
full house's Avatar
It seem to be a bulb problem, I think that happen to me and the mechanic told me it's has something to do about the bulb.
lemmon_water
Jul 1, 2015 05:18 AM
camryvasaq
Jul 10, 2012 07:38 PM
marty anderson
Jul 20, 2011 10:50 PM
distantarray
May 24, 2010 04:14 AM
Mark61
May 18, 2009 08:34 PM
