3.0 swap into a 2.2 camy
This could get complicated very fast!
This year car had two V-6 engine model options. Either one will require the appropriate engine computer for that model. This for year, trans as in stick, emissions standards built to, etc.
The most common V-6 was a 1MZ-FE. However Toyota made changes to the engine as time passed. A later model engine had a later model computer to accommodate these changes.
You will need the proper engine model wiring harness to fit up to computer plus whatever options your car has.
The V-6 uses a different model stick trans. The old should bolt up but not sure of the axle fit when bolted to a V-6 engine. The L4 and V-6 axles are different.
The V-6 had stronger front suspension springs.
Individuals have swapped L4 for 6 cyl. They typically had access to a complete donor car of the same year to swap parts and do it cheaply.
