Old Aug 28, 2015, 10:55 AM
How-Tos on this Topic
Browse all: Engine Diagnostics
Print Wikipost
Camry Ignition troubleshoot guide
Old Mar 4, 2012 | 10:24 AM
jmarr01's Avatar
Default Camry Ignition troubleshoot guide
Looking for a troubleshooting guide for Ignition problems. I have followed the trouble shooting guide in the Hayes manual and have not found the issue.
No Spark
- Distributor is clean and dry
- Power to the distributor is 12v
- Internal coil resistance checks passed (replaced anyway)
- Power to the Ignition Control Mod is 12v
- AutoZone performed test on ICM and passed
- Fuses all look good and hear a click at the ignition relay
Need help to continue this troubleshoot process.
Old Mar 4, 2012 | 10:42 AM
Year of car and engine model?
Old Mar 4, 2012 | 09:54 PM
ukrkoz's Avatar
Old Mar 4, 2012 | 09:55 PM
ukrkoz's Avatar
Old Mar 5, 2012 | 02:03 AM
jmarr01's Avatar
The year is '92 and the engine is the 4 cyl 16 valve. I found the problem and have spent the rest of the day replacing the broken timing belt.
At the same time I have also replaced the water pump which is right in the same procedure as the timing belt. I have followed all the procedure as I understood and I must have missed one of the finer details of the spark timing.
I have spark now but still have not got a start. Given the belt broke I returned the crank and cam in their proper TDC positions and following the procedure hand cranked 1 full cycle to check all the alignments. All looked good.
My suspicion is that I have the distributer 180 deg out.
Old Mar 5, 2012 | 08:35 AM
What proceedure did you use to get the cam and crank pulley at TDC?
centrespectre
Jul 9, 2022 04:34 PM
KEVAUG
Mar 9, 2012 12:12 AM
Paul79UF
Dec 30, 2011 05:09 PM
penhaifai
May 16, 2009 03:06 PM
1992I4
Feb 21, 2008 12:56 PM
