Difficulty removing solenoid SL
I removed the electrical plug and two bolts to what I believe is the "lock up" solenoid SL (E) just behind the park/neutral switch on my 1997 toyota camry le 4 cylinder automatic. However, I cannot seem to pull out the solenoid from the body of the transmission. My understanding has been that it was removable from the outside of the transmission without having to remove the oil pan to disconnect it on the inside of the transmission.
Any help would be appreciated.
solenoid sl passes electrical tests & found TOC for manual
Thanks to the help I got, I removed the solenoid sl with 2 flat bladed screwdrivers, 1 under each bolt hole tab. I also tested it OK for resistance. It clicks solidly with 12V applied, though it may not have the first several applications. Now I am going to somehow apply 71 psi of air and check for leaks. Then I will follow the advice and manual for checking the wiring harness.
I also found the icon in the upper left corner of the adobe reader that displays the table of contents for this excellent manual.
I did notice that there were two different settings given for the TV cable adjustment in different parts of the manual. I noticed at least one other seeming anomaly as well. If I get time, I will try to reconcile the differences.
resistance test while solenoid activated
I bench tested the solenoid SL for resistance with a meter and got 12.6 ohms, which is within range.
I applied 12volts to the solenoid SL and it activates (clicks) and I can see the holes opening and closing.
I applied 71+ psi and found no air leaks.
Instructions in the manual said to also test the resistance while the solenoid was energized. I energized the solenoid with current from the 12v battery positive terminal to the single input terminal on the solenoid and the battery ground connected to the case of the solenoid.
I simultaneously tested for resistance with a meter between the input terminal and case. However, I got absolutely no resistance reading.
The instructions say any reading below 8 ohms means the solenoid has a short.
As soon as I removed the 12v connections, I got the normal resistance reading of 12.6 ohms again.
Does this really mean the solenoid is bad? It doesn't make sense to me and I'm not sure I'm even performing the test right, though the instructions seem clear.
(I haven't gotten to the wiring harness test yet.)
Are you using the info sent in the pdf link? And if so the Diag. Trouble Code Detection criteria for Code 46?
If so, this is the criteria the computer uses to test the solenoid (not mechanic). If the solenoid fails these criteria the code is set. From the criteria the code is set based on the electrical condition of the solenoid, wiring or ECU.
It's the Diag. Trouble code 64
Though whether the resistance can be measured while 12 volts is flowing through the solenoid is beyond my knowledge at this time.
So, I'm going on to testing the wiring harness.
Thanks.
dsmith222
10-23-2009 10:03 PM
1997, 99, camry, disconnect, located, location, lock, resistance, sl, solenoid, solinod, solonoid, toyota, transmision, valve
