Rear Control Arm Help.
Hey there, I'm new to this forum and was introduced to it by a friend. I recently purchased a 98 camry and had the drivers side rear lower control arm snap on me. I've gotten all but one of the bolts off to remove the old one and this last bolt has me stumped. I've taken an impact wrench to it, soaked it in pb blast. Any help on how to get it off would be appreciated!
might be rusted in or worn /bent out of round
picture suggests it can be removed
see if you can buy a replacement before doing something drastic ...
does this exploded view help you or attachment
1998 Toyota Camry Parts - Toyota OEM Parts | Toyota Original Parts
Do you know anyone with a torch, if so heat the knuckle where the bolt installs and the area behind the head.
Impact wrenches can at times have varying degrees of success. Try using a 1/2 inch driver, 6 point impact socket and large breaker bar. Or even larger size drive.
Is this unit still on the car, if so take it off via the suspension arms and work on it the bench when installed in a vice.
If all else fails might cut the bolt head off to remove the arm and use a pipe wrench on the bolt shank. Sometimes cutting the head off removes the bolt tension and the bolt now rotates.
Daniel Saucedo
03-16-2015 10:10 AM
vin888
07-12-2007 09:28 PM
italianjeremy
05-14-2007 09:37 AM
unsub
01-19-2007 04:48 PM
