Toyota Front Engine Mount 12361-0A080 Question
I am replacing my 2003 Toyota Camry LE 3.0l Automatic Transmission engine and trans mounts. I bought aftermarket mounts and three (Top, Left and Right) went well. The front when i removed has a hose so i believe its vacuum controlled front mount. The aftermarket i bought says its compatible but does not have the hose and Now i am little concerned if i can install it or i should just buy the OEM part.
The part i bought is below
Please help.
Please help.
Can you use you vin and check what is the oem part number by checking with an online dealerships parts. Then use this oem part to compare with the technical details on the amazon order.
Manufacturer Part NumberENAMMS113304
EMT9211, EMT9212, EMT9197, EMT9165, 9211 9212 9197 9165, A4203, A4211, A4236, A4207, 12361-0A080/12362-28110/12363-20100/12372-28020
You may of done this already but buying parts on Amazon can be tricky. Its amazon so even if you have three of the four installed they might let you keep it for free if its a wrong part number and no need to return..
Try checking the OEM part number with the VIN on https://www.toyotapartsprime.com/ . Hope this helps.
Thanks everyone.
I believe i found the part. Here is the link
https://www.toyotapartsdeal.com/oem/...60-0a080.html?
Yet to get it to make sure its correct. but looking at diagram it looks like its correct.
