2005 Camry SE 4cyl. Door Lock Problem
I have a 2005 Camry SE 4cyl. with a Door Lock Problem. The switch will ONLY lock all the doors and will only UNLOCK the drivers door now. I have replaced all fuses and got a new PW/PDL cluster...still not joy, I still have to reach over to open the lock, I even removed the pos battery terminal for 15 minutes...still nothing. How can I remedy this so the switch afgain unlocls and locks all the doors like it used to. This started happening 2 months ago, and I was able to use the swutch reset procedure in the user manual...it no longer work either. Any help would be great. Thanks in advance
FT
FT
I have discovered that alot of Toyota Camry's of this Generation(2002-2006) have a specific door lock problem that develops. This problem occurs when an internal part of the Car Computer/Fusebox under the drivers dash burns out. This results in all the doors locking, but ONLY the drivers door unlocking. You loose the Unlock function of the Passenger side door and both rear doors. If this is your specific problem, then Toyota's ONLY Fix to this is to replace the Car Computer/Fusebox at a cost to you of $700-$900.
I have designed a Module to bypass the burnt out internal parts externally. There is no need to remove the Car Computer/Fusebox from the car. I include a detailed install guide that is COLOR CODED with PICTURES. The Bypass only requires 7 connections. I include all the needed connectors to make these connections. You can purchase this from me on EBAY, just do a search for "Toyota Door Lock Fix" or item #280735700457
If you have any questions feel free to contact me through EBAY's "contact seller" link. This is the fastest way to get in touch with me.
