2007 XLE - VSC light on after replacing headlight switch
Old 01-22-2023, 08:31 AM
p032504's Avatar
Default 2007 XLE - VSC light on after replacing headlight switch
I disconnected the battery before removing the steering wheel. Replacing the headlight switch was pretty straightforward, but then when I started the car up, the Check VSC light came on & has stayed on.
I think the steering angle sensor needs to be reset or calibrated?
I have tried several things I’ve found online but nothing has worked so far (unplugged battery again, paper clip in 4 & 13, tried turning the VSC off with a series of steps involving pushing the brake pedal down and turning the car on & off).
Is resetting the SAS something I can do myself? I’m also freaking out thinking maybe I didn’t plug something back in but don’t want to take the steering wheel off again. (99% sure I did plug everything in).
Pretty sure an alignment place can reset it but how do I know my VSC is working?
Old 01-22-2023, 02:27 PM
Did you perform the zero point calibration for the yaw and acceleration sensor first?
Old 01-22-2023, 03:43 PM
p032504's Avatar
Nope. I bought a very basic scanner. Think I can do it with that? ANCEL AD410 Enhanced OBD II Vehicle Code Reader Automotive OBD2 Scanner Auto Check Engine Light Scan Tool (Black/Yellow) https://a.co/d/ihRmZUc
Old 01-22-2023, 03:48 PM
p032504's Avatar
If I take it in for an alignment, they should be able to do it too, right?
Old 01-22-2023, 07:23 PM
Yes. Its a procedure issue to fix as in resetting, not a mechanical issue.
Old 01-22-2023, 08:08 PM
p032504's Avatar
Phew. Thank you!!
RByers91
11-29-2021 05:18 PM
Singh
02-05-2018 12:01 PM
CollinJ
12-25-2016 07:18 PM
rmkuper
12-20-2013 05:47 PM
camry man
08-18-2008 06:57 PM
Quick Reply: 2007 XLE - VSC light on after replacing headlight switch
