engine not starting after new battery
my 97 camry battery was dead due to non-operation for the past 4 months.
I replaced the new battery however the engine is totally dead now.
is it due to fuse issue?
any suggestion please?
If totally dead check the battery cables and end terminals for damage or corrosion. Check the negative terminal ground point on the chassis.
There is also a fusible link between the battery and the cars main electrical supply. Should be in a small plastic box in the engine compartment.
the desolate one
Sep 7, 2019 03:36 PM
2007xle
Aug 7, 2009 09:50 PM
