HELP- I can not find a fuse
Old Apr 25, 2020 | 06:25 PM
hotrod69boss's Avatar
Default HELP- I can not find a fuse
I just got a super nice 94 Camry LE-75,000mi.-from my mother in law. The power windows and door locks did not work so I put in a new combo window/door lock assembly and the windows/door locks still do not work. I used a test light and found no power to the new assembly. I was told there was a 30amp fuse behind the coin tray. I could not find it. I called a buddy and he said "the fuse is in there-look harder". Can someone tell me where that fuse is and how to get to it. Any and all help would be greatly appreciated. Thanks---Rod
Old Apr 30, 2020 | 06:20 PM
Try the right upper side of this panel. Note the 30A fuses bolt on and does not plug in.
Old May 1, 2020 | 06:25 AM
My buddy came by and I showed him the fuse panel behind the coin tray. He pulled a panel from beneath the steering column, then pulled the a/c duct work in front of the fuse panel. Dang there was a lot more fuse panel back there . He reached in there and unplugged a 30amp fuse. We replaced it and everything worked. Did not see any fuses that were bolted in. Thanks for the info. Rod
Old Jun 23, 2020 | 11:19 AM
jami's Avatar
yes its behind the coin tray try pulling the bottom panel out and look up behind the coin tray its right there
eripike
Jan 30, 2011 01:51 PM
dkrausatc
Oct 29, 2009 07:41 PM
spoolin
Mar 29, 2009 07:35 AM
FSVeloz
Nov 18, 2008 07:23 PM
FlyingDaggers
Jun 23, 2008 05:53 PM
