radiator fans turn on with ignition
Old Aug 8, 2016 | 09:52 PM
hexacube's Avatar
Default radiator fans turn on with ignition
hi, i have a toyota camry 1998 4cyl. (5s-fe engine).
when i turn the key to the "on position" the both radiator fans turn on while the a/c is off. i have checked fan relays 1,2,3 and they are all good. voltage tested the ect sensor connector (reads 5v).
could it be a faulty fan switch in the radiator? i checked the voltage and it reads 12v from the connector. what should i do from here to solve this issue?
Old Aug 9, 2016 | 10:03 AM
The fan switch is CLOSED when the coolant temp is below the set point needed to turn on the fans.
If the switch fails in the OPEN position or the harness plug to the switch is disconnected or there is an open wiring fault to the switch. The fans will turn on.
Check for an open switch or wiring issues.
Old Aug 11, 2016 | 12:23 AM
hexacube's Avatar
thanks i will do that.
Old Aug 11, 2016 | 01:00 AM
hexacube's Avatar
how much voltage should be flowing to the cooling fan switch connector when car is on? should it read 12v?
Old Aug 11, 2016 | 09:51 PM
Use an ohm meter on the switch. The switch should be closed.
The switch will always have 12V if the ign switch is on.
Old Aug 15, 2016 | 02:46 AM
hexacube's Avatar
OK i replaced the cooling fan switch, i just plugged it in while leaving the old one in the radiator, a/c was turned off and both cooling fans connected and they both still turn active when the key is in the "on" position, car was dead cold.
Did i do something wrong or could the problem lay else where?
i tested the new switch and it has like only 0.03-4 ohm of resistance so its good.
Old Aug 15, 2016 | 11:27 AM
The temp switch plugged in or not makes no difference in the fans being on or off?
Is there any change in fan speed (faster/slower) when plugged into the switch or not?
You checked the relays to make sure the relay power switch turned off when the solenoid is not powered?
KEVAUG
Jan 5, 2023 09:09 AM
egarci10
Jul 8, 2011 09:52 AM
justinw
Jul 11, 2010 06:44 PM
aarong34
Aug 16, 2009 09:22 PM
fleshbone
May 15, 2009 02:46 AM
