07 camry v4 maf sensor 02 sensor maybe ecu
Old May 23, 2024 | 02:22 PM
justjeff's Avatar
Default 07 camry v4 maf sensor 02 sensor maybe ecu
I have a 2007 camry v4 gas, I put new plugs in it new Coils, a new 02 sensor and a maf sensor. Its still giving a code for o2 sensor lean, the mass airflow sensor. We had it hooked up to a code reader and the voltage was way off. Sitting at idle had high voltage and the voltage for the mass airflow seemed to be consistent eith the o2 bank 2 sensor. When the car is driving after it gets warm it starts to shake and jerk, no power like I'm out of gas. It has died once. Any ideas?
Old May 23, 2024 | 02:24 PM
justjeff's Avatar
P0420 as well cat code
Old May 26, 2024 | 08:42 AM
Inline 4 cylinder?
Any other codes besides P0420?
Code P0420 is usual a bad converter. It has happened the converter is plugs up. A vacuum gauge can show if the exhaust system is plugged.
Old May 30, 2024 | 09:36 PM
Agree with Joey, usually a cat, especially if the o2 sensor has been replaced.
user2020
Oct 11, 2013 12:33 PM
jamesn
Apr 10, 2011 10:06 AM
temo
Nov 12, 2009 11:15 PM
Hippo393
Jun 10, 2007 08:18 PM
azazel1024
May 2, 2007 12:11 AM
