Video - 94' camry 2.2 engine noise - bearing?
Old 07-28-2018, 01:31 PM
WesCV04's Avatar
Default Video - 94' camry 2.2 engine noise - bearing?
Hi guys. If ya'll can take a minute to listen, insight and suggestions appreciated. Sounds like it's behind the exhaust manifold in the block somewhere but could be under the valve cover (screwdriver method). I'll pick up a proper stethoscope soon and update, but accessories area was pretty quiet. Father's car with 131k original.
Searched around but didn't find anything similar sounding.
Last edited by WesCV04; 07-28-2018 at 01:33 PM. Reason: Edit: I know it sounds like like a bearing in the A/C or alternator but it's not.
Old 07-29-2018, 04:36 PM
Sounds like something powered by a belt.
Use a section of rubber hose as a stethoscope.
Check A/C compressor,alt and PS pulley bearings.
Check for noise under timing belt cover.
urbs00007
08-04-2018 07:27 PM
finbar
08-18-2013 05:49 AM
Penguinlord777
12-07-2010 10:16 AM
EagerBeaver
05-25-2008 10:13 AM
EagerBeaver
05-09-2008 09:13 PM
Quick Reply: Video - 94' camry 2.2 engine noise - bearing?
