Video - 94' camry 2.2 engine noise - bearing?
Old Jul 28, 2018 | 01:31 PM
WesCV04's Avatar
Default Video - 94' camry 2.2 engine noise - bearing?
Hi guys. If ya'll can take a minute to listen, insight and suggestions appreciated. Sounds like it's behind the exhaust manifold in the block somewhere but could be under the valve cover (screwdriver method). I'll pick up a proper stethoscope soon and update, but accessories area was pretty quiet. Father's car with 131k original.
Searched around but didn't find anything similar sounding.
Last edited by WesCV04; Jul 28, 2018 at 01:33 PM. Reason: Edit: I know it sounds like like a bearing in the A/C or alternator but it's not.
Old Jul 29, 2018 | 04:36 PM
Sounds like something powered by a belt.
Use a section of rubber hose as a stethoscope.
Check A/C compressor,alt and PS pulley bearings.
Check for noise under timing belt cover.
urbs00007
Aug 4, 2018 07:27 PM
finbar
Aug 18, 2013 05:49 AM
Penguinlord777
Dec 7, 2010 10:16 AM
EagerBeaver
May 25, 2008 10:13 AM
EagerBeaver
May 9, 2008 09:13 PM
