code P0420
Old Jun 19, 2022 | 07:03 PM
spotteddog's Avatar
Default code P0420
Will running a can of Seafoam through the gas tank of my 2003 Camry 2.4l cause it to throw a P0420 code? I put a can in a fresh tank of gas 2days ago. Today,after a 200 mile trip, a check engine lite came up. OBD reader came up with a P0420 code. The car is running fine. Did I trash the cat ? BTW the car has 200k miles on it.
Old Jun 20, 2022 | 12:52 AM
I would try running out that tank of gas and then disconnecting the batter overnight.
Maybe it just needs a reset?
I'd start with that before starting to do any work/or throw parts at it.
Old Jun 20, 2022 | 06:54 PM
spotteddog's Avatar
Thanks for the reply. I live in a county in Texas that does not require a smog check to pass inspection, so I'll run a couple of tanks of gas through it, reset the CEL and see what happens. If the CEL keeps coming on, I'll spend $100 for a cat just to keep it stock.
Old Jun 24, 2022 | 11:33 PM
Sounds like a good plan.
Any news?
Old Jun 25, 2022 | 01:09 AM
spotteddog's Avatar
Well, apparently a full can of Seafoam in a tank of gas is too much for the o sensor to handle. I ran it down to half a tank, topped it off, ran it down a quarter of a tank and the CEL light went out. Lesson learned, sometimes too much of a good thing can be counter productive.
Old Jun 26, 2022 | 01:30 AM
Sounds like it worked out!
Could've ben worse I guess.
ghostuser01
Mar 8, 2022 03:29 PM
Diggger
Sep 8, 2021 11:00 AM
Waseq Ul Azad
Jun 22, 2018 11:36 AM
rick oshay
Mar 25, 2017 08:50 PM
broncobilly
Nov 4, 2009 01:04 PM
