09 Camry low beams not working
Old Sep 26, 2021 | 06:16 PM
FunkyFiddich's Avatar
Default 09 Camry low beams not working
The low beams on my 09 Camry both stopped working within a few days of each other. When I try to turn them on, the right one will occasionally work for 20-30 seconds but then it goes out. It might flicker on briefly but it only stays for a few seconds. The left one just won't turn on at all. However, when I turn the switch on and take the bulbs out of the assembly, both of them are kind of "on": they are both lit up dimly but that light isn't visible when they're in the assembly. (images in link)
Both bulbs are less than 3 months old. I tried fresh fuses and replaced the headlight switch, neither made a difference. The running lights and high beams both work fine. What else could the problem be?
https://imgur.com/a/z6vM92y
Old Apr 11, 2022 | 09:22 AM
Rennox's Avatar
Check the voltage at the bulb socket ,
Check the high and low beam relays, faulty relay can cause issues (unlikely to be the case , but dont rule it out)
Check your wiring to the bulbs and the relay junction box (most likely)
Check your positive and ground side of the circuit
Savannah DesireƩ
Nov 10, 2019 08:54 PM
pipe
Nov 5, 2019 08:41 PM
Granpa49
Dec 15, 2017 12:12 PM
egarci10
Jul 17, 2011 05:10 PM
