1992 camry 2.2 surging?
Old Oct 12, 2011 | 09:36 AM
imabadczech's Avatar
Default 1992 camry 2.2 surging?
My camry has been running like a dream. New cv axles, new motor mounts and a few other things and it has been an awesome car. The only issue I have now is a slight surging I call it. When the car is warmed up good, you can be at a light and every once in a while, you feel a very slight "surge" but not a real big one. It is almost like when the fan comes on however, that isn't the case. I cleaned the iac and throttle body but I did notice it was still doing it. Could this be a simple fix? Yes, it only does it in gear at a light. When it is sitting and idling, it does not do it. When I am cruizing at 80 on the hwy, it rides like a dream.
Any help would be appreciated.
Craig
Old Oct 12, 2011 | 11:56 AM
At a light as in trans in gear?
Does the tach RPM indication change?
Old Oct 12, 2011 | 10:39 PM
Joey,
Yes, when I am at a light with foot on brake. It isn't a big surge but a slight one. The rpm's hardly move at all. I have also noticed this happens in reverse often as well but not always. When the car is in park or neutral it is as smooth running as a new car. Would this have anything to do with transmission?
Old Oct 13, 2011 | 11:16 AM
***update***
Well, I am stumped. When I was out driving around this morning, it was doing it more often than ever before. I also noticed that the rpm's do move a bit but not much maybe 100-200. It does it a lot when car is in reverse now and often in drive when sitting still. I am so thinking it is a tranny problem but not certain. It would make sense if it was. The transmission shifts like new when driving so that puts a little doubt in my mind. UGH!!
Old Oct 13, 2011 | 06:23 PM
FIXED!
The set of plug wires that were on the car were defective, so I went to NAPA and got a good quality set of wires and now the car runs and drives like a new one. I cannot believe that it was wires that caused all this.
Thanks y'all.
Craig
Lindsey Spence
Jun 20, 2016 06:56 AM
corey l
Apr 30, 2010 09:47 AM
ckelner
Apr 20, 2009 07:09 PM
Mikesta
Mar 20, 2009 08:00 AM
mychem23
Feb 20, 2007 06:33 PM
