1993 Camry LE, 2.2 4-cylinder just won't start. Stumped...
Old Feb 28, 2011 | 12:49 AM
luberack's Avatar
Default 1993 Camry LE, 2.2 4-cylinder just won't start. Stumped...
Hi Folks,
I hope some of you with may have seen this before and have a solution for me. I've got a 93 Camry wagon, 135K, with the 4 cylinder automatic that won't start.
I have a new battery and can crank it endlessly. The motor will turn, but never fire up.
History:
  • Starter seemed to be going bad. Sometimes I turn the key and nothing happens, or just a click. After several more tries, I can get the motor to budge a little bit. Then a few more tries and it will finally catch and start the car.
  • Sometimes, when it finally does start, it really chugs and has a rough minute or so before it settles out.
  • Last Friday, I had the same problem. Took a couple of key turns to get the starter to engage and start the car. Got home and parked.
  • Saturday afternoon I went out to start the car and it just cranked and cranked.
What I've done so far:
  • Spark Check. I have good spark on all 4 plugs.
  • Replaced: Spark Plugs,
    Wires,
    Starter
  • Inspected distributor cap and rotor.
  • Verified that rotor turns when cranking (timing belt intact)
  • Pried cover away and verified timing belt looks ok
  • When cranking with plugs out, saw vapor, smelled gas (getting fuel)
Strangeness:
I shot starter fluid directly into the intake, and it had no effect at all. I would have expected the engine to run a few seconds on just that, but it didn't even sound different.
So, I'm stumped. Anything you think I've missed?
THANKS.
Old Mar 3, 2011 | 09:09 PM
If a click when attempting to start and the starter and attached solenoid was replaced check the battery cable, terminals, battery cable ground, ground strap between engine and chassis.
Sometimes a few teeth will fail on the timing belt resulting in the belt moving on one of the pulleys. This causes the crank/cam shaft timing to be off.
A stuck open EGR valve can cause problems.
Any change in starting if you apply some gas?
A failing computer coolant temp sensor can cause problems.
Yota
Apr 3, 2015 10:55 PM
charlie64
Aug 26, 2011 10:17 AM
redtree
Jul 12, 2011 06:20 PM
maxima8347
Jun 13, 2010 11:13 AM
dbzfan112287
Sep 6, 2008 02:08 AM
