1995 Camry 4 Cylinder 02 sensors
I have a 1995 Camry 4 Cylinder California car.
The car calls out for 2 O2 Sensors but I can only find 1 up front after the exhaust.
I have the car on jackstands and checked the entire exhaust for the downstream 02 sensor and cannot find another sensor.
What am I missing?
Would a VIN number help in identifying how many 02 sensors are on this car?
What am I missing?
Thanks for the advice
Yes there is a catalytic converter and exhaust muffler. I can clearly see the upstream 02 sensor just off the exhaust manifold on the front of the engine. I examined the entire exhaust to the catalytic converter looking for that downstream 02 sensor and its associated wire. None to be found. I even ran my hand above and around every exhaust component to the exhaust muffler and cannot find this sensor. I can send you some pictures if that would help. I do appreciate your advice.
Update:
Strangely I think I found them.
If I am not mistaken they are both accessible in the engine bay and not under the vehicle like most other cars.
Thanks for the advice!
Here is a picture.
Update:
Here is a picture.
02 Sensors replaced and smog problem solved
Yes I changed both 02 Sensors as I did not get a check engine light but it failed HC and C02 levels. After a drive of 100 miles I took it to my smog shop and passed.
You saved me a lot repair shop money. 👍
Thanks!
Thanks!
