1998 Camry need advice..........
Old Jun 6, 2010 | 11:34 AM
mercerman's Avatar
Default 1998 Camry need advice..........
I have a 1998 Camry LE 6 Cyl. with 58,000 mi.
It has a rough idle and acceleration, check engine and Trac Off light is on
Code indicates a misfire on 5
I have changed the spark plug and everything checks out fine with the wire. Any idea what might be the problem? Thanks, Dave
Old Jun 6, 2010 | 11:01 PM
Do you have the exact code number?
Trac light may turn off when CEL comes on to lighten engine load.
Old Jun 6, 2010 | 11:31 PM
mercerman's Avatar
Thanks Joey,
Nope didn't get the exact code, just a reading from Autozone that read misfire on #5. I'm thinking I have a bad injector because if it were the fuel pump/filter wouldn't that cause the same problem in all 6 cyl.? Seems like replacing the injector myself might be a complicated because of all the stuff you have to remove to get to it. I'm open to ideas and opinions? What should I expect something like this to cost me?
Dave
Lunareclipse02
Sep 29, 2011 10:09 PM
LetterX
Oct 30, 2010 06:20 PM
mercerman
Jul 18, 2010 04:29 PM
jake679
Jun 29, 2010 07:44 PM
illwillwvu
Mar 10, 2008 08:48 PM
